Hey guys I know this has been discussed in detail many times, although my tail pan is not coming out as easily as some say it does. I've drilled all the spot welds on the floor pan and cut the tail pan so the center section fell out. Now my problem is the corners. I see a bead of weld where the floor pan meets the corner post and another bead down where the bumper would be. It seems as though the sheetmetal inside the tail light is spot welded to the tail pan as well. Can anyone who has done this say this is true or not? Also if it is spot welded... how the hell do I drill those spots out? Or do I just cut out that L shaped tab at the bottom of the corner post inside where the tail light goes?
