Mudmanmaniac
Registered Member
Hi everyone, this is my first post! I was wondering how many of you k5 owners have power rear windows or manual and would you change to either or if you had the option?
Jeremy
Jeremy
I've had both on different blazers and i would never go back to a manual crank window. The convienence of being able to lower/raise the window while driving is awesome. Imagine driving down the hiway and all of a sudden it starts pouring and your rear window is down and you can't pull over or stop right away and you have something in back that CAN'T get wet, just click the switch on the dash and UP it goes.
This is just one scenerio and obviously not a critical factor to go one way or the other but as i get older i don't want to stop everytime i want the window up or down. Each style will work correctly if kept properly maintained so it's really just a preference on your part. The manual cranks are known to break so you might be replacing a few in the time you own the vehicle.
