k5 with bedliner
bushmaster
ct
looking for some pics of k5's with bedliner/stone gaurd on rockers and lower fenders/bedsides
thanks
Herculiner on the bottom.
Don't do herculiner. It's junk unless you put a ton of coats.
Rocker guarded the entire inside and exterior up to the body line.
Rocker guard is a bit less obvious than the bed liner idea that many use.
Very durable!!
I've seen johns in person. I'd go with that rocker guard. It looks alot more clean also.
Thanks Adam!!
Appreciate the complement Adam.
Your rig build deserves major props too!!:waytogo:
The bedliner is tougher and a bit thicker but the rocker guard seems to lay a little more smooth.
I wasn't knocking any of the bedliner ideas only offering a different option.
I defiantely like the looks of it John. I've had to paint over my herculiner like 5 times because it bleeds through in the sun.
I'd go rocker guard or a catalyzed bedliner (has hardener unlike herc or duplicolor stuff from auto zone) if I did it again.
I used herc on a previous truck. Didn't like it. That stuff is IMPOSSIBLE to clean, so the rig always looked filthy. I also had it on the interior, and it's incredibly rough which means scraped knees and hands and such. Imiceman has that truck body now, and he could probably clone me based on getting a full genome from the amount of flesh left in the back of that truck from moving building materials around in it. :haha:
