As you mostly know my passion was in restoring my Blazer to factory stock. That meant getting a Rochester Quadrajet. I didn't modify any of the fuel delivery system.
Fast forward almost 5 years and it has not been driven as much as I like because of a lot of things...but those aren't important.
I would be interested in hearing your opinions, particularly those that still have carbs.
1. Do you still use the factory Quadrajet fuel filter? What is your experience with replacement intervals and any issues with the stock filter or those with the anti flowback valve.
2. Those of you who have trucks with carbs and are not daily drivers, what have you seen as regards to truck setting for maybe months?
3. What carb products do you use? cleaners..etc..
4. How many of you went with an external fuel filter and have you put it on the suction side (between the tank and the fuel pump (mechanical)?
5. What "tune up" items go bad when the truck is sitting for weeks at a time?
Thanks for your input in advance.
aaaand mice. Crank for a few seconds, 2 pumps and it will usually start.
