CUCV2
5/4 ton fun
Just trying to do some finish work on the short bed crew cab and having the emergency brake working would be super handy since it has a NV4500. Not to mention legal ~. When you do the conversion, 14" of frame is removed right behind the cab. Everything else in that area needs to be shortened 14" too (ie - driveshaft, hydraulic brake lines, exhaust). There is probably some smart way to do this but I am still exploring to find out what the best (and safest) option would be. A few of the ideas that I've had are relocating the rear brake cable holder, the part that attaches to the frame and serves as a junction for the three cables to come together, 14"back. This would put it right over the axle and in the rise of the frame causing poor geometry for the cables to function correctly. Another idea was to find another front cable that would work with the new wheelbase. The wheelbases for squarebodys are;
-CCLB 164.5
-CCSB 150.5 (obviously but I need to write it out for stare and compare purposes)
-Suburban 129.5
-RCLB 131.5
-RCSB 117.5
The last idea I had was to do a cut and repair on the existing cable. They do have emergency cable repair kits that might work but they seem like they are made in China. I have better luck with parts made in USA.
Any ideas from those that have gone before or have encountered similar issues would be greatly appreciated.
Included gratuitous pics of the project.
-CCLB 164.5
-Suburban 129.5
-RCLB 131.5
-RCSB 117.5
. Sometimes the bracket will come off without even knocking the rivet through, like it did on this ebrake bracket. Just give the bracket a couple of love taps on both sides until it's persuaded.
..torch is THE easiest way..
