Keeping the truck level with a 4" lift
Can Can
Pusher Man
Cochrane, Alberta, Canada
Keeping the truck level with a 4\" lift
I'm under the impression that in order to keep a truck level when installing a 4" lift, you have to install a set of zero-rates in the rear.
Am I correct? /forums/images/graemlins/dunno.gif
Re: Keeping the truck level with a 4\" lift
Depends on condition of rear springs.Also depends on whether your shackle flipped or blocked. I assume most blocks are close to same height from kit to kit. Mine actually sits a little higher in the rear with my flip. /forums/images/graemlins/k5.gif
Sorry, I should have been a little more clear with my description. /forums/images/graemlins/whistling.gif
No shackle flip, no blocks. New 4" springs on all four corners.......
OH , then I guess it just depends on the spring rate and free arch. /forums/images/graemlins/thumb.gif
I did the ORD flip and 4" Superrides in front.
If my gas tank is empty, it sits just about level.
When full..it sags about 1" /forums/images/graemlins/frown.gif
I wouldn't see why you would have to worry about it w/ all new springs, just keep the mother in law out of the back seat /forums/images/graemlins/whistling.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
John
[ QUOTE ]
John
[/ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
Paul, on my K5 I put all new 4" TC springs and needed the zero rates to level it out. /forums/images/graemlins/usaflag.gif
[ QUOTE ]
[/ QUOTE ]
Most likely due to the D60 front gaining you some unwanted extra height.
Rene
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
Rene
[/ QUOTE ]
Good point, tho that extra height certainly wasn't unwanted...... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
