LS swap it.
i am still on v-belt, this is the pump i ordered, which the description says is for a serpentine belt, but says direct fit for 87 blazer... Shoot, guess i need to call the parts store. Thank you for the heads up on that.
What was he fix? Don't leave us hanging.I think i'm finally good to go. Thank you all for the help. On to my next adventure where I get in over my head, haha.
X2. Looks designed to turn counter-clockwise.I do believe that is a reverse flow impeller
It's hard NOT to get an air pocket when flushing all your coolant out. It helps to have a thermostat that has a relief hole in it, I think most do anymore. Glad you got it running cool again. Supposed to be 110 here on Friday and Saturday.Didn't want to say "i dunno" and get stoned to death. haha... Best guess is the water pump, but i took the old one apart and nothing looked busted on it, but I don't really know what i'm looking for. It did overheat once more after the new water pump, but i discovered i didn't have the lower radiator hose on good enough, and i was having problems getting it to take 4.5 gallons of coolant. I fixed the hose, made some adjustments on the belts, (was getting a squeal first starting it up) and then would just run it for 10 minutes or so, and then check the coolant to see if i could add more after it cooled. Maybe there was an air pocket in there preventing it from taking all the coolant, i'm not sure, but it's cycling coolant, and i've driven it around town and the temp gauge has been reading good in this 100 degree weather. Now just need some highway time to triple check.
On the plus side, everything's been replaced cooling wise aside from the radiator and heater core.
