original balzer
My crew cab is getting crossover/highsteer and hydro assist. I was looking through pics of how people have it set up and mounted. Seams most mount the ram to the top of the springs. While this dont seam that bad I still dont realy like the idea of it. so I was brain storming and came up with this. why not build a mount that ties the inner sprong plate bolts on the pass side and a ring under the diff cover and a ring under the pinion seal housing. I even made a rough drawing. Note that I would probably lay the tie rod in front of the cylender. I drew it this way just to show the idea.
I figure you would be best to ask if this would work, or point out any drawbacks to this. And if you could build it.
Also worth mentioning is I have about 9-10" of lift, a custom engine cross member and will be moveing the front alxe 3-4" forward. Im useing JKW's high steer crossover arms.
Balzer
Balzer
