Yes, the motor cranks when I'm trying to start. Belt, fan, alt, are all turning.darkshadow said:when your cranking it does the motor spin? (look a the fan)
Yes, dash lights are coming on as usual when I try to turn it over (brake, service engine soon lights).darkshadow said:are the lights and gauges in the dash comeing on with the key?
I'll try pulling all the fuses to see if any are blown. Is the fuel pump located on the frame rail forward of the gas tank or is it in the tank? Sorry for the noob question but this is my first FI truck. Every other one I've owned has been carbureted.darkshadow said:pull all your fuses just to be sure and check them i have found things i dident think were togeather tied in to different things.
,aybe check the voltage to the fule pump when you turn the key.
Thanks again for the help. --Don
