This is just a safely reminder is all more then anything, and some advice that Will help possibly if you use it. In my shop and of course anywhere, but especially a garage shop you have Brutal steel and wood corners that will kill you or certainly can injure you. Something I've used and done for years is use the floaty noodle foam thingys from the dollar store and cut it up for bright colored protective bumpers around the shop. Believe it, It helps. When you swing a hand and accidentally smash it against something hard and sharp that's steel or anything and it hurts, then you do the same and it's a soft pad, It's awesome Not to feel that pain.
Safety cones placed to where they will move works too. You don't want to slam immovable objects, especially sharp ones. You WILL lose every single time. Like the cone I have on the wood shelf. I want to finish these shelves and they will have radiused corners at the front. But until I get these finished I want the protecting of sight, seeing it visually, and a buffer of movement so I have time to react hopefully in time not to take the brunt of a full impact that causes a worse injury. My biceps have both taken a beating on my dirtbike handle bars sticking out. Deep bone bruises hurt damnit.
collector,that too needs to change..
...that tire is going to be taking a trip to the dump,that didn't belong in the garage either..
