im thinking that would cost a lot. time no big deal. money right now is. may be i would be better finding something cleaner
,if yer bucks are way low find some roofing tar/thin with whatever you can afford and blow that on there(i guess?),,,,when you shop for undercoaters they start with cheepest being basically asphalt(not paintoverable without melting) plastised(you CAN paint over it but it's still black in color) and texture for matching finishes on rocker panels,,the cheapdog undercoater is actually the best for killing rust since when it gets hot it `gets loose' and soaks in
Por-15 would be wonderful!!!!
it's a converter, por15 is an encapsilator..
this is my 86. i know the body needs a good amount of work. not sure how to keep it from getting worse. was told a spray on line is a good way, but i thought that was for rust free trucks. to prevent rust from starting. so any help would be great. here is a few pics thanks
really? just used oil. that i have like 6 gallons of. never heard of that one thanks
sweet, a good cheap way thanks
