Kinda rusty now, how to stop from going further
i thought oil would be to thick for those. thanks ill try it. hope it working out with your truck
There's really nothing scary about the frame rust in those pictures. It takes a long time to actually weaken the frame. You will rot through the body parts much sooner. Still, rust is inherently hideous.
I get my cars sprayed with this thick grease every year or two. I don't know what it's called, but it coats your tools, hands, everything as you work on the vehicle - very sticky! There is a local shop that does it for about $200 and then the "touch ups" are only like $30. They recommend this every 3 years, but mudholes and dust have a way of wicking the stuff off much faster.
If you can find somebody who does this, you won't even have to knock off the existing rust - unless it is really loose. It slows the rusting a lot because air and water are no longer getting to the metal. It moves around a little on hot summer days and it doesn't seem able to trap water underneath it.
