King of the Hammers LCQ race prep
Air bump work
For the those that aren't familiar with an air bump.
They are a real short air shock of sorts. They have compression and rebound valving just like a shock and then they have a spring rate of sorts that is controlled by the pressure charge applied to them.
The recomendation that King gave us was to cut the travel down to 2" on them as a 2.5" air bump is large for a 4500# vehicle. Then change the compression valving to # 12 stacks.
The stroke is easy to change as you just add 1" spacers as needed over the shaft.
The three AL. pieces on the shaft are the spacers. There is one in place all of the time we added the other two to reduce the bump stop travel to two inches. The rest of the items visible are the bump strike pad on the right then the seal gland and it's retainer, then the spacers, then the actual business end of the bump stop where the valving and piston are located.
This view shows the head of the shaft with all of the valving removed. It was at this point that we slipped the two 1" spacers on as seen in the last pic.
This view shows the fully assembled valving and piston. Starting at the bottom is a large washer that I have no idea what it does. There is a small spacer that goes on top of that then the compression valving stack slides on, the piston goes on then the Rebound valving on top of that. Last thing to go an is another longer spacer then the nut that holds all of that stuff tight.
This top view shows the rebound valving sitting on top of the flow piston. The piston has a oil seal on it that makes all of the oil in the shock/bump go through the piston and by the valving.
The valving is just a stack of washers that are a set thickness and Diameter. I think these were .010". You can do all kinds of things with the diameter of the washers, adding small washers in between large washers etc. I am not going to get into all of the specifics as I don't fully understand them to the point that I can explain it but there are limitless possibilities with the valving. The compression valving is the same type of setup.
Completed air bump with 2" stroke, ready to be filled with 150mL of shock oil, installed and charged with 50lbs. of Nitrogen.
A rebuild able shock like my Kings are identical to this just the shaft is smaller and the flow piston looks a bit different otherwise same thing.
Valving by each of the shock makers is called out differently so where King my call for .012" valving Fox would call for #50 valving. There is not a chart that correlates this info to have a cross reference guide that is open to the average guy like us that I know of.
Hopefully I don't have to have a serious talk with Jack Thursday night before the race:D, since I will be getting the car ready for 8+ hours of the worst beating we can hand it and still make it live to cross the finish line.
What are the odds of that?:thinking:
Sorry I don't do humidity.:p:
We always talk about making it east but then something good in the west shelves those plans.
I can't blame you too much for the good stuff in the west distracting you from coming out, but I think you can deal with humidity for a week or so.
BTW, will I get a ride during a practice session?:whistle:
Would you like Jack or Brandon to take you for your ride?:D
Heading to Cali. shortly for a test and tune day. 72 hr round trip to Cali:doah:
So it has been beyond busy trying to do my real job and help get the buggy (car) ready for the race.
We had a good trip out for the LCQ prerun. We ran back door a few times, got our heads straight with our strategy for the LCQ as much as we could without knowing what the exact course will be.
Then we headed out into the desert for some higher speed testing. The poor tbi 350 would push the buggy 60 mph across the lake beds but we didn't have anything left. This we just have to live with.
The shock setup is nice, we were able to push the car harder than I have ever pushed it and not bottom out even on some decent sized whoops sections. This is a good thing and it actually rides better the harder you push:D
We were able to get our bearings again since it had been 5 years almost to the day since we were last at the hammers and had a good time.
Made the round trip to and from Colorado in 72 hours :doah:
Once we got back we were able to address a few of the minor issues that we found while pre running.
I have been driving the buggy as it is now for 5 years, Stephen had spent a total of 1/2 hr. driving it until we went to Pre run. Of course he has a bit different driving position than I do so we are making a few creature comfort changes to adapt peddle positions etc. to work for both of us.
We have been around enough to know that cooling in a race is way different than cooling on a trail ride. With that in mind we have added a PWR tranny cooler in addition to my existing cooler, also we have a second PWR cooler that will act as a giant heater core/2nd radiator.
We will probably end up adding in a power steering cooler as well even though we have never had a problem with it the way it is.
Since I am so good a regular maintenance :rolleyes:we decided it was a good idea to tear both of the axles all of the way down and look at all of the bearings and ring and pinions etc. There were a few of the drive slug spacers in the front that had changed shapes, the bottom of the rear dif had worn down enough to need a patch welded in to make the bottom bolt of the 14bolt actually have threads on the bottom side of the hole :haha:
All in all things were in okay condition for not having anything done but a oil change once a year for the last 3 years.
So here we are 2 days before we leave and 1 tow rig is still having it's new transmission built, the car is actually close to being able to have it's panels bolted on and stickers applied.
Thanks to all of the people that have helped out, donated parts, time and money.
Thanks to:
Mrk5: I think the roof is going to be awsome thanks. All of the stickers look great.
Nate/Hooptiebuilder: The hood is more than I expected, you really went out of your way on this to help out multiple times. BTW. Nate does custom work and is really good. Hit him up if you need something fabricated.
Toby/moneypit: Thanks for getting all of your junk worked on, (by Nate:p:) loaded up and driving 17hrs to come help.
Dawn and Tana: You always manage to make sure I eat and that means a lot to me.
Thanks to Steve Fox/CK5 for your help in getting us to the race.
PSC; Got us out of a bind when we found that my steering cylinder was bent a little bit at the last minute. They built a custom one off ram on short notice to fit what we had put in 5 years ago.
And last but by no means least:
Huge thanks to Offroad Design and their shop guys
Working on the car during the day, staying late, staying even later and then be standing next to us a 1:00 am when we figure out that we need to take 5 steps backwards in order to make 1 forward. With no questions asked just grabbing the wrenches and taking things apart because we just didn't think things all of the way through.
No pictures right now. My camera has been taking terrible pictures and budget cut backs are a b!tch so I can't buy a new one.
Hopefully before we load it on the trailer on Saturday we can get some good pictures of it completed and ready to go.
Good luck dude. Its a long drive so I hope you make it through the LCQ. I will be out there helping some J**p buddies, one is in the main and one will be against you in the LCQ.
I was poking around Pirate looking at the KOH coverage and saw that Miniwally qualified for the race. Looks like he finished 4th in the LCQ. I always enjoy seeing my stickers on the race vehicles. :D
I can't find where he placed in the actual KOH race Friday. Here are some pics that I came across:
Hey scott I want a pic of the C & B Racing. lol I gotta see that.
quote=mrk5;2456038]I was poking around Pirate looking at the KOH coverage and saw that Miniwally qualified for the race. Looks like he finished 4th in the LCQ. I always enjoy seeing my stickers on the race vehicles. :D
[/quote]
Damn Miniwally looked lean and mean! Way to go Brothers Watson!!!! It is fun to personally know The Watson Family, ORD Family and how well they represent Off Roading in Colorado and across the nation.
Their website says they finished 14th, would've been better but they had water pump issues. By the way that 14th place finish was out of almost 100 rigs, way to go guys :bow:
Small video clip on their home page http://www.offroaddesign.com/
I just got home, great weekend! The Watsons did awsome! These guy's are a class act. I talked to them a couple of times, great to meet them. Our pit was a coouple hundred feet Norh of theirs at pit 1. Kerry Steiner broke a rear output shaft about mile marker 40 so she never made it in to pit one. Here are some pics of the Watsons in the pit. They were there long enought to put fuel in and split. Man there were some sic rides in the race and just running around all weekend!
I'll try to get a race re cap up but WOW!
Everything is still a blur but we made it home today and got unloaded and everything settled back in.
The car took a beating but with a few hours to pull the water pump and re seal the plate on the back of it it is still ready to rock. It's still running but I am not sure how long the water pump will remain not leaking.
Spoolnaround it was good to meet you as well. I am sure that we met more of you out there but I just can't remember at this point.
Good job guys. I had fun watching you race and wheeling with some Colorado guys after the race (I was riding in the back of the 4-seat F-toy).
Sweet. I was in the k5 buggy leading the trail. Didn't know you hung out on ck5. right on!
Hehehe! There I am in the orange vest! Stephen wanted me to wear his "hinting vest" so it was easier to see where the pit was coming into the pit at a rate of speed....They were out very quick! Had a blast too!
I was sure that was the moneypit setting there, couldn't miss you either Toby! Sure hope you guys didn't beat miniwally to bad Brandon I might want to ride along again! :) :) After looking at those rock formations do our trails seem easy? Did you take Wally or Cousin Willard to play around with on other trails?
CONGRATULATIONS TO YOU BOTH!
