- Joined
- Jul 18, 2000
- Posts
- 1,695
- Reaction score
- 2,115
My friends did an 8.1L swap to his 72' K20 with 4l80e and np241 case recently.
Things they used
- Denali radiator
- Stock Intake
- 8.1 with comp cam
- Blackbear tune (they are datalogging it right now, to send in)
- Used stock motormounts that were in the k20
- Suburban fuel tank with in tank pump
- Lokar shifter
Overall this thing is a monster, if the truck could handle going over 105mph safely it would do it with ease. It's on 35's and 4.10's gears but this thing has some diesel torque. Can't wait till they program the stupid torque management out of the motor. After riding in this I think that i'm gonna do a 8.1 swap myself in the K5.
Cool!
Yeah, just having some ECM tuning done and removing TM makes a huge difference. My stock 2001 Silverado with an 8.1L and my ’78 K10 with a stock 8.1L run night and day different from each other just due to ECM tuning. Now my ’89 Suburban with a RayLar cam runs entirely different than the ’78 K10. The Suburban is also in the midst of getting tuned so it will run even better once the chop gets tuned out. It has a date with a Dyno Tuner in late May. I can’t wait!
Hopefully your buddy didn’t really retain the stock 67-72 engine mount design as I doubt those will hold very long with an 8.1L. My ’68 GMC 2wd with a bored and whored 396 has habitually ripped apart the driver’s side engine mount over and over. In fact, back in the day GM even had a recall to add a cable from the frame to the driver’s side exhaust manifold because the engine mounts breaking were so common. The reason they tied the engine to the frame was because when the engine mount broke it would jam the throttle linkage rod and stick the throttle wide open. What most people do to fix the sucktastic engine mounts on 67-72 trucks is to install 73-87 engine mount frame brackets then use the 73-87 clam shell type engine mounts. The clam shell mounts are much more durable than the old single bolt design. Safer too!
Meanwhile, Ls engines are starting to go for stupid money.
. I find them much cheaper and easier to install than a LS small block with greater rewards in the end. Many times one can find an 8.1L for less money than a small LS engine because most people don’t know anything about the 8.1L whereas the demand & knowledge base (and price) for used LS engines has gone crazy. An 8.1L is even an easier swap if you’re going from an older BBC to an 8.1L as there would be no exhaust work needed to be done. The only downside I can think of is finding an 8.1L, although they seem to be popping up more and more lately. As with any late model engine swap don’t be surprised that the install bits and pieces (harnesses, fuel lines, air induction, etc.) cost more than what the engine costs itself. It is not uncommon to for an $800 engine to end up being a $4000 engine swap by the time everything is all said and done. As I’ve said many times before, I am not a promotor of using a donor truck harness. Pony up the money and buy a fresh stand-alone harness. It would be the best $600 a person could spend on a late model engine swap.
