I am sure mine are the same, it has the ticking at idle once it warms up.got back to this project, have had a ticking noise since I purchased. I pulled the intae for the egr delete and both valve covers leaked some. Inspect push rods per tsb
Fist 3 exh push rods pull all show damage
That looks like two problems, a slot that leaks, and also it appears the rocker is rubbing on the pushrod every cycle? I'm not talking about the guideplate rub, thats normal, I'm talking about the groove worn around below the ball. Normally a 210 degree clearance pushrod ball would solve this, but it almost looks too low?got back to this project, have had a ticking noise since I purchased. I pulled the intae for the egr delete and both valve covers leaked some. Inspect push rods per tsb
Ok, if they don't, let me know, we'll get you something that works.I believe the gm updated push rods have a longer taper.
I have 8 of ea on order from Rockauto. Will post up a comparison photo when they arrive
My push rods arrive while I was away playing.
comparison of exhaust push rods.
View attachment 499830View attachment 499831
The part numbers match the tsb
