They go on in any positionI just removed the crank pulley/dampener, and don’t see any indexing device. Does it not matter how it is installed?
Google fu has failed to answer my question.
Yep. Stupid they are so small. I can hear on mine one either backed off or broke.exhaust manifold studs?
Do you know of any success stories?Short of drilling out the head to put the same size hardware the earlier big blocks used there isn’t a simple fix.
I agree that HW store stainless would not be a good solution. I was thinking of getting some (known good) factory studs from another application. The factory 8.1L studs are likely some form of SS.I think I would swap them for ARP stainless before they corrode. It's stronger and corrosion resistant and can take the heat. Regular SS is weak and galls with any heat.
That looks painful! I can here the dissatisfaction!If you own a 8.1 you know this battle . Or any late model with smaller size hardware that always brakes .
Do what you can. Just don’t be surprised if you snap a couple. Like I said I was able to break one that had backed off a little by going a little past snug with a 3/8” ratchet handle. No power tools, just my big bear paw on it.Hmm. This is the first I've heard of this stud issue.
I guess I'll start soaking the studs with Fluid Film now, while it's still in the running donor truck. Maybe if I constantly soak them and give them some heat cycles, it won't be an issue later on.
