All serp drives are reverse rotation at the pump. TBI or L31 vortec. I know the older system should bolt to the Vortec block and heads without a problem. The support struts that come off the a/c bracket to the intake may not work with the stock Vortec intake setup, but that wouldn't be too hard to modify.
The L31 may have a spin on fan clutch vs one that is bolted on at the water pump. If you have the correct tools, it is a slick way to attach the clutch. It sucks balls if you don't have the wrench and holder tool.
