last owner?
the general
prinsenbeek(the Netherlands)
he guys:D,
i am looking for( i think) the first owner of my 75 k5(i am the owner since march 2003 here in The Netherlands), i now his name was Jeff Duane and that the car was originally light bleu with a white stroke on the side and when he sold the car it was darkgrey metalic, it has an 8 inch liftkitt(superlift), an 2 inch bodylift and the seller here in the netherlands said an 383 stroker, it has a white polyester cabrio cab, the official licenseplate was:657TDT
After the year2000 the car was on the name: Denson Janeen Rea on the same adres(his wife or girlfriend?)
does somebody now these people ?:confused::confused:
hope too get more information here
Best regards Pat , The netherlands:bow::bow::bow:
I think you should probably remove the physical address portion of his information. I wouldn't like it much if you put mine on the 'net. :) (even if you can likely find it out anyway)
I'm checking whitepages.com for you, might get lucky.
No luck on Duane, but if you check whitepages.com for denson rea in CA, you get a few hits. Not sure if you intend to talk to them or what, but at least you've got something.
Interestingly enough, I used to live off of a Mulholland growing up. In '94 I bought a CJ7 from a guy named Jeff on Mulholland from a guy that had a K5. I will look tonight and see if I have any more info as I used to drive past that address everyday. Do you have pics of your K5 when purchased?
he guys:D ,
thanks for the reaction, i now it is not common to put somebody,s adress and everything on the net sorry for that:crazy: ! but i thought this is one of my last chances so thats why i did it. how can i post a foto on this site? is it possible for a not full member? my car is also on the site Holley.com, virtual show ,choose trucks and i think on page six you will see my orange 75,k5 this is the current state. hope this works!!!
regards Pat:bow::bow::bow:
The netherlands.
Hoi Welkome vriend! Ike Lawrence.
To put a photo in you need to use a host like photobucket.com or one of the others. If you use photobucket it is the second line on picture info to put it here. Once you do that click on the yellow square picture above reply box where you type. Then paste the link in there.
To remove the address in first post click on the edit button and just delete the numbers in address and street.
I hope you see this before you go slappen! Truste!
