Kain
3/4 ton status
and by cold it dropped from 60 deg to 19 deg that night its 3 deg this morning
...That is because the ones for the military have grid heaters in the lens.The military has gone iver to all LED headlights. The ice/snow thing hasn't been an issue.
Nope. Regular plastic. Every one we ever broke was just regular plastic over the LED's.That is because the ones for the military have grid heaters in the lens.
No luck, changed the wires around. Cleaned the grounds attached to the frame... I know there is power to the tan wires at the plug, I know the LEDs are good, tested a fused line with the battery, all light up. Started snowing, so will have to try later.
Exactly Desert...I'm going to keep researching, will let you know budThis is the exact problem I'm having. I even used the LMC harness since I'm a wiring dummy. I have power coming from both hi and low beam wires but can't get it to work. If I wire the high beams the low beams don't work and vice versa.
85what year are your rigs?
ya for some reason you have to switch the wires before it works properly.
what i did is just turn the lights on without the engine running and switched em till it worked.
they dont draw enough amps or power to hurt it
