LED light
4X4HIGH
1 ton status
Fremont, CA.
Ok, where can I find some of those small LED lights that you drill a small hole and push it into the hole and it is pre terminated with wires already? I need some in a few different colors for my gauge build to use as a high beam indicator, brake light, turn signal indicators and SES light.
radioshack. They have them in green yellow red blue and white. And they're 12v so no resistors
Radio Shack online is your friend. I think the hardest for me to find was blue, but green, red, and yellow were all readily available.
Edit: ^^^^^^He beat me by seconds.
Ok, care to give me a link because I looked at www.radioshack.com and couldn't find them.
EDIT: After another quick search I did find them but they don't have a blue one.
Blue was the one I had the issue with finding as well. My thought was to use the old blue plastic lens from the gauge and attach it inside a simple white LED if I couldn't find one.
Blue Seas make real nice pigtailed LED's, they're what i run in my breaker panel... but alas, no blue...
superbrightleds.com is gonna be getting my business here in a bit. plan on replacing all but my headlights with LED's.
Nice, all 4 colors in one size and the 1/2" diameter should work well for my plans to put symbols on them.
