I might add that when I first got my '72 K5, it had a 283 intake on it with the smaller Rochester 2GC carb off a '67 Impala the previous owner swapped on it,he insisted it ran "way better" with it than the Q-jet it had originally...
He had the original intake and carb and he gave it to me when I bought the truck..I drove it a good year with that 2 bbl on it,and it didn't seem to get any better mpg ,it still got around 15 mpg in combined city and highway driving..
I soon got the urge to have a 4 bbl,and I found a used Weiand dual plane intake for 10 bucks a friend had ,so I put that on it with the Q-jet..it sounded much more impressive,especially with an open element Moroso air cleaner I also got for cheap on it,but it did no better on gas,probably worse,because now I had to boot in the secondaries it sounded so cool more often...
Then I found a used Carter AFB for 25 bucks at a swap meet,I put that on it and it really ran great,much more "boot" when you kicked in the 4 barrels..it would get about 16 mpg if you drove like a granny,but when you booted it it would suck gas down pretty good,it'd get 10-12 mpg if you hot rodded it around town..
In the end,I regretted taking the 2 bbl off it,especially after I swapped a SM465 in it in place of the TH350...if you lugged it down instead of downshifting,it would buck,ping and lurch with the 4 bbl carbs...they proved to be troublesome in cold weather too,they iced up and stalled ,the chokes were not the best either,the Q-jets choke coil spring thing let it stay on too long and kill gas mileage,and the AFB's electric one was too finicky,I ended up converting it to a hand choke..
I decided to put the 2 bbl intake and carb back on it,with the stock air cleaner all hooked up right --and what a surprise--it could now be lugged down to nothing in third gear,and when you gave it some gas--it pulled up nice with no bucking,pinging or lurching..it DID have more low end with the smaller carb and intake ports--much better "driveability"....it lacked the top end thrills the 4 bbl gave though,and the gas mileage stayed about the same overall..and the choke worked right and with the "heat stove" on the air cleaner working it didn't ice up and stall on foggy mornings any more..
So in my experience a 2 bbl may not improve gas mileage much if any,but one will increase low end torque some,and give better driveability..I guess the air flows thru the smaller venturi's faster and that improves low speed performance some..
or better than us for having the combo
