Lets see pics of FORD hi pinion dana 60s installed
cybrfire said:
Here's one.
More pics of that rig! :eek1: :bow:
...the main page at the bottom??? Not all that current but shows the basic exterior layout.
Trust me man the pics dont do justice to it, Ive seen it in person, and Im sure Kert will say something but the whole time i was up there i couldnt keep from staring at that thing :D
Hopefully Kert will be welding a set of his beadlocks onto my steelies next spring and I'll make a trip down there, from seeing his attention to detail on here I'm sure the truck will be killer, one of the reasons I plan to make the trip myself.
Y'all prolly know, but the 78-79 also bolts into YJ's. Same spring perch width. I think this has some to do with the high cost. It doesn't help that 4WOR said it was/is the "best" axle made :surepal:
uhh no they don't. If a 78-79 bolted right into a YJ, so would our Chevy axles. They need to widen their spring spacing to fit a full size chevy or ford axle.
I think the reason most people dont do the swap is simply because of having to change the tcases. I know of 2 people running them and I believe that both are running the ford versions of the NP241 with slip yoke eliminators. Personally had I been more knowledgable when I built mine I would have gone this route. Hi-pinion, 2.68:1 low, fixed yoke with the option of getting a driveline e-brake.
I swear I tear out a drivline slip seal every other trip out.
nope :D
I've broken 3 knuckles (well, 2 broke & 1 cracked) & Dedenbear has been a lifesaver for me. I did all 3 with nothing more than a stock steering box. I had the ram assist on when I did that roll & wish I had video of that pic, I was steering & still trying to drive before the pic was taken. If you look real hard my ram is on the drag link, so all the stress of the box & ram is going through 1 knuckle. What can I say, they dared me to try & break one. :D
I thought they bolted in too :what:
I could be wrong & I will NEVER claim to be an expert on J**p anything (thank God)
I figured GM & Dodge would be an issue since YJ's are drivers side drop...
