The Mule said:Just make it a convertable
are you talking to me? if so you are on the right track. there are changes to be made.
Speedo said:This is an old pic from around '79-'80 45" tires with 6.5" lift 60 front, 70 rear, 5.86 gears and Detroits in both ends.
Gus
86Cucvbeater said:Man, you have the coolest pictures. Do you have a photobucket album are something? I can't beleive you had this awesome setup back in 79. Dana 60's weren't even popular till what, 1998 or so? ahaha![]()
Speedo said:I had a Dana 44 for a Dodge and I traded him the good 44 for the bad 60.
gmc4cw said:without a 60 in the front you will burn through axle shafts on 44's. I lied to myself and said I could go easy on my 44 until I got a 60. after breaking a stock shaft, then a warn HD shaft wheeling, then a warn HD shaft messing around in my driveway, I realized a 44 would never survive no matter what.
Good luck .Speedo said:This is an old pic from around '79-'80 45" tires with 6.5" lift 60 front, 70 rear, 5.86 gears and Detroits in both ends.
Gus
