The picture in this thread wwere so awesome that I got all fired up. I have teh metal and will build my anti wrap bar today...I'll post some pics. Thanks again for the info.
sweetk30 said:is it just me or is ( FRIZZLEFRY ) end mount for the frame up side down . all i have seen are bar on top and frame mount on bottom. will this make a diffrence?
BKinzey said:So, is RuffStuff selling a complete kit now? I thought they just sold the axle parts and you made your own ladder and frame connection?
, when you change engine location, transmission length, transfer cases (length), or double the transfer you are changing the correct position to locate the crossmember end. We can't decide that for you ahead of time without making 10 different length wrap bars, and then we still would likely be off from the prime location by an inch.......Did I make sense?
Im not a fan of these type of traction bars... They create issues when the suspension cycles. A look at renes post a while back explains this well. A single bar on each side properly laid out with orbital eyes/ rod ends would be a better overall performer...A look at wally (ord's rig) has this setup and worked very well when they were still on leaves...
Basicly the issue with these barsis that in a normal sprung suspension there is little to no change in the pinion angle as the suspension cycles, with this style (dual bars- triangulated) as the bar moves up and down it moves in an arc, and trys to rotate the pinion with its arc. Since the pinion doesnt want to move like this it puts TONS of stress on that bar/ bolts...
There is a heim on the end of the bar at the shackle to allow rotational movement? What am I missing? I do not agree at all with individual bars, drag racing yes, rock crawling no.....
There are two mount points on the diff end, and this style of anti wrap bar does not jive well with the way the diff wants to move. One of the mount points on the diff end will always shear eventually.
You need to compare the pinion's arc of travel through the limits of the springs to the arc of travel of the anti wrap device. It's not about the fore and aft compensation, and it's not about the twist due to articulation. It's how those two arc's I just described cannot jive with each other. What part breaks only depends on what the weakest link is. On my set-up the weakest link was the alloy 1/2" pins.
Frankly, the best way to get rid of axle wrap is to link the rear. Anything else is asking for a lesson in 'weakest link' theory.
Rene
All of this was cnc'd from billet, bars were 1.5" x .375" DOM. Shackle ends of the bars were threaded with some high end aircraft grade unobtanium stainless alloy inserts. Both bars could rotate 360 degrees...certainly more than any heim out there.
Shackle had free and adequate movement.
Springs were 57" F150 springs, and with the bar it would ramp 1200 plus on a 20 degree ramp (42" + under a rear tire).
Add throttle while twisted, or while seriously compressing the springs and snap goes one of the two diff mount pins
Rene
