On a SF axle design you have to combine the two sources of stress (the full weight of the vehicle plus the torque being applied to the shaft) then account for the cantilever loading which is bending the axleshaft while the torque is being applied. That is probably closer to 10X the stress of the FF axle design where you only have to look at the torque applied to the axleshaft that does not see any bending. The larger diameter of the 14SF axleshaft vs/ the 14FF axleshaft is compensating for the inherent weakness, but overall is a weaker axle in the end.
It is however a very decent axle for smaller tires (33-36") and would not break under most situations. I ran an 8 lug 14SF in my '79 K10 with 33" tires and hauled many heavy loads and still used it for mild wheelling with no problems. I'd trust them over a 10 or 12 bolt any day.
The Dana 60 FF compared to a 14SF however, the D60 is going to be a better choice and still give you the better ground clearance and close to equal ring gear size. Plus when you do finally break an axleshaft on a full floater you pull out the broken piece, cap off the outside and drive home on front wheel drive. On a semi floater you better have the correct spare.
