lets talk motors and horsepower
Looks like I just found the new background picture for my desktop! /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif
need also:
Compression ratio
transmission choice
bore & stroke (stroker intentions? more cubes need more cam)
RPM range desired
gear ratio
tire size
total vehicle weight
intake manifold choice
carb/efi choice
if EFI, MAP or MAF
etc.
You certainly need far more info than, "Vortec heads on a 350 block"
stock,the 350 goodwrench comes with 8.5 -1 ,700r trans,but i think the vortects might up that 8.5-1......rpm range = im after low end torque,513s like in my sig,38s,weight=unknown,intake is a edelbrock performer,re built carb /forums/images/graemlins/thumb.gif
If all you're after is low end torque and you're using a stock bottom end, I'd leave whatever cam is already in the engine.
A high performance cam to increase horsepower is going to need compression, and 8.5:1 isn't enough.
I personally wouldn't run Vortecs with less than 9.5+:1 as it is a lot of expense to give up power by not having the rest of the system matched.
8:1 is being optimistic with the targetmaster crate motor
sorry
it isnt a good foundation unless you change out the pistons
Stock Vortecs don't like lift over .450"
Crane told me my cam (it's been so long I have to go find the box to get specs on it, duration of something like 204/214) requires a better spring than the Vortecs come with stock as well...something like 90lb springs stock, need much more than that with a bigger roller cam. The new beehive springs might well solve the problem with Vortecs and the bad stock springs, but still added expense.
Edelbrock Etecs might be a good bet, I had looked into them previously, but not too in depth. The Fast Burns might be another choice, but I'm betting those heads are better suited to high RPM power, not low end torque like the Vortecs.
Dont' forget Vortecs stock require rail rockers, no re-using non-rail stuff.
Mine needed pushrod clearancing I guess because of the cam. Stock Vortec was like .420" max lift.
Flat tops and Vortecs got me around 9.2:1. Should be no problem on 87 since the Vortec chambers are so much better than older heads, but I haven't been able to test them under load yet. Soon.
Pro-toplines are probably a better choice than the Vortecs. Better components off the shelf, same price or less, and seem to be a prety good quality head both in flow and casting. (thicker too)
