Is anyone already running a LiFePo4 in their truck?
Pretty good article here about replacing dual battery/lead acid/AGM batteries with a single LiFePo4 https://www.takethetruck.com/blog/overlanding-battery?format=amp
I feel we are still early enough in the LiFePo4 story to see whether prices will continue to drop, and/or something better comes along before they replace lead acid/AGM. But with the cost of starting batteries being what they are now (Walmart selling 800CCA group 78 starters for $140), and the quite short life they seem to have, a battery with an 11 year warranty and probably a far longer lifespan if used simply as a starting battery, holds appeal.
Still a lot of money, but I think if dual batteries were a consideration, these should end up costing less in time.
The Dakota Lithium 60Ah starters are $600. Unfortunately those still have a ways to go IMO, as they are unheated (no charging under 32*) and limited to 80amp alternators. At 16.5lbs though, you'd probably never break the stock battery tray lol.
I haven't checked to see who else is making starter LiFePo4's, so there may be alternative LiFePo4 batteries already out there that are better suited to "truck use". Again, based on my opinion that 80 Amp max input may be too low for some applications, and an automotive battery needs to charge under all conditions. There is more consideration when it comes to charging as too. Since they will shut off charging, I believe that would spike alternator output.
While I don't do a lot of camping that requires power, you could certainly replace a generator with an inverter and use the "starter" battery for a fair bit of power if you needed it for a 12v fridge, TV, etc.
Definitely appeals to my gadget side lol
