Hmm.. so a 4" lift would be 14"? I read 16ish" is a 6" liftno lift is 8.5"
Please do...thanksif I remember next time I am at my house where my blazers are I will measure. one has a 4" lift, one a 6" lift and one a 12" lift.
I thought you measured to the bottom of the front bump stop bracket, which I guess is the same.A 4" lift should measure roughly 12.5" between the top of the front axle tube and the bottom of the frame, 12.5" - 8.5" = 4".
Yeah according to some numbers in that thread, I have a 6" lift... weird why would ORD say I have 4"? I've ordered everything from them according to that lift height.I'm pretty sure the bottom of the frame and bump stop are basically the same. In the thread I linked above we specified the bottom of the frame.
I’ve heard & read a lot of good things bout Tuff Country springs, figured I could inquire to all y’all here in the 4x4 world. Your opinion’s & experience with all the different brands, before I purchased my lift kit.For bang for the buck....
Tuff country 4 inch springs
Ord or diy4x shackle flip with stock height springs.
Bilstien shocks at all corners.
Will ride good, from there you can build off of it and upgrade as you go.
I will tell you what I have on my Jimmy and you can take it for what its worth.I’ve heard & read a lot of good things bout Tuff Country springs, figured I could inquire to all y’all here in the 4x4 world. Your opinion’s & experience with all the different brands, before I purchased my lift kit.
Ya rear lower leafs are twisting, overload & next two up. U-bolts are not close enough to perch . Yes I believe the shocks are cheap too .
So I hear a lot of ORD on here, & I get it they specialize in square bodies but are there any others ?@MrHappy
Here, ask your lift questions here.
