[ QUOTE ]
Ok, it's time to give the old girl a suspension lift. Here is the big question, though: How high can I go before I need to get longer brake lines, shocks, drop the t-case and regear? My research seems to indicate that 3" is the cut off, so I'm thinking I will get 3" springs for the front and a 2" shackle flip for the rear with a 1" add-a-leaf. Suggestions? Comments?
[/ QUOTE ]
unless you have lots of flex in your suspension, you can go up to 4" with the stock length brake lines. You are prolly running with an anti-sway bar, so your stock ones should be fine... for now. With shocks, you'll need some longer ones. I really like DT8000s myself... they are good n cheap and they work about as well as any low-priced shock will. Whatever you do, avoid super stiff shocks like the RS5000. Dropping the tcase... not sure about 87s, but my 85 had factory 1" spacers on the tcase x-member that you can use to lower the the thing a bit. This will help with driveline angles and driveline lengths... but if you have lots of suspension flex, your shafts will need to be lengthened. If I was you and on a tight budget... this is what I'd do...
front springs: 4" BDS springs from
www.jdsoffroad.com
pitman: find someone here on ck5 than has gone x-over and get a drop pitman cheap
rear: 4" shackle flip from ORD
tcase: use factory spacers if ur rig has em, if not various lift companies make little spacer kits.
u-bolts: go to a local spring shop, they can make em cheap
shocks: DT8000s from summit, oughta be $35-ish each, free shipping.
with that stuff you can lift 4". For Phase II of your lift...
ORD HD front shackles with greasable bushings
ProComp stainless brake lines
lengthen driveshafts if needed for max flex
ditch the factory anti-sway bar
which will round out the lift nicely.
j
