You said you're trying to do this as cheap as possible so why not just use a regular old lift kit? Front lift springs, rear lift springs (or even a spring/block combo), a fresh set of shocks and steering correction (dropped pitman arm, dropped drag link, raised steering arm or a combination depending on the height and manufacturer of the lift kit).
You said you like mud and sand. I can tell you with a shackle flip in the sand you're going to have such bad wheel hop w/o a traction bar you won't be able to drive it. I have a shackle flip with ford 57" springs out back and I took it on a shake down run to the dunes before I built my traction bar and it was a mess.
