G-Force8
So I've seen Blazers with off-the-shelf 6" lifts that didn't need any driveshaft mods
Trying to get all my ducks in a row before I shoot
I'm planning on installing 4"TCI ez-ride springs with ORD zero-rates up front and a combination of a 4"shackle flip,ORD 6.0"rear SuperShackles and an ORD zero-rate out back with the stock 56" springs.......on my '91 'Burb
I don't want (can't afford) driveshaft work, as I'm building this truck in phases and I'll be rebuilding the NP241 later on with an SYE,bigger chain/planetary and custom built shafts
Has anyone with about 5" of lift up front and about 6" of lift out back encountered any driveshaft binding/fitment issues on a Suburban with the slip-yoke style NP208 or NP241 transfer case?
Really need the stock shafts to work for now
*also*
I will be swapping a 14BFF under the rear in place of the 10-bolt at the same time using a conversion u-joint
*also*
