just thought id share my experience on my k5. i used 4" tc springs up front and ord shackle flip in the rear.
when i first installed the lift i had some vibrations on my rear drive line, so dropped the tcase an inch and that helped some. then i got shims, i believe 6 degrees, put them in and raised the transfer case back up. that got my slip yoke and pinion within a degree or two and my driveline vibration went away. but the combination of raising the tcase and pointing the pinion down some pulled the slip yoke out enough that it vibrates like hell on the tcase output shaft when i let off the throttle. this vibration is different than the driveline vibe in that its not felt nearly as much as you can hear it, its loud and a much higher frequency. im pretty sure just lengthening my drivelines will solve this.
