I am looking for the proper way to lift my 1986 one-ton flatbed diesel... All I want is about 4-6 inches of lift, nothing too crazy... Some day I d like to get a 4-link done though, just not yet...
I've heard of people using 1/2 or 3/4 ton front springs, which are obviously softer, and then some cheap blocks on the back... I am not planning on hauling a bunch of weight, but would not mind a bit softer ride and more articulation... My front springs are 49" and rears are 56"... Are all front springs the same? So, if I just picked up a cheap used block lift kit from say a Blazer or Sub, would it just bolt in? Or are there some diffeernces? Am i going to need a drop pitman arm with a 4" kit? Am I going to need to change the driveshaft or axle angles (its longbed, 135" wheelbase)???
What are the pros and cons of using lower-rated springs?
Also, how about rear blocks vs shackle flip vs add-a-leaf?
