lights issue
aknight_sa
Saudi Arabia
good day all,
the problem I have is as follows:
  • headlights and tails lights/breaks work normally
  • when I switch the turn signal on (right or left) the front signal works normally, but both rear signal lights go on together as if the warning lights are turned on
  • when I use the break, everything stops blinking and just stay continuously on, even the front signal lights.
what could the problem be?
signal switch?
Had a truck once with some goofy issues. Turned out PO had stuck single filament bulbs in double filament sockets.
