aknight_sa
good day all,
the problem I have is as follows:
what could the problem be?
signal switch?
- headlights and tails lights/breaks work normally
- when I switch the turn signal on (right or left) the front signal works normally, but both rear signal lights go on together as if the warning lights are turned on
- when I use the break, everything stops blinking and just stay continuously on, even the front signal lights.
signal switch?
