linking the front?
muddybuddy
1 ton status
Northern, VA
just curious if anyone has done 3 link or 4 link in a fullsize up front, and opinions on it. i know sled dog is doin an s10 blazer, but im curious bout on a fullsize. i remember reading a tech article on it a while ago, but lookin for more info. thanks
Watson's rig was linked up front for TTC. That'd be a good place to start! I've always thought linking the front (first) made more sense than linking the rear. I guess it depends which is more important, approach angle or departure. Anyway, I'll be following this thread... Im interested too!
j
I'm pretty sure Greg72 is, and willyswanter. Those are the only ones I can think of right now. I was debating linking f&r but with 52's or 56's up front and 63's in the rear, there really is no reason to. Plus then you dont have to buy very expensive shocks or coilovers
I've got it planned, but not built....
Linking the front is a LOT harder than the rear (which is probably why you don't see it as often)
Oil pan clearance is a concern with the links
Tire interference with links (when turning) is a concern
Finding a location for a crossmember to hold the frame-side links is tough
Building the structures to hold the coilovers isn't trivial either.
It's definitely possible, but I've only seen a couple on a full-size ever. JuanBlazer has one, and Watson has the other. Willyswanter has one too now that I think about it....
ive already got 64's in the rear so i want to keep those, and i was plannin on doin 56's up front. then a heep friend was talkin to me and mentioned linking the front instead of longer leafs. i saw the technical article with the yellow k5 with coilovers upfront...it looks sweet, and flex's really well. thought i would explorer the option
