see if any of you have had this issue putting blazer back together after 9 years apart and lock works fine with door open but once i close door and lock them i cant get them to unlock without basically banging on the latch at the lock pivot with a hammer or something heavy thought it was the lock cylinders causing the issue since i had just put them in but does it with or without them installed
