easttxryda
Whats goin on fellas, I plan on installing the powertraxx lock right on friday into a 10 bolt rear.. Anything to really look out for, or any tips.. I've heard i'll have to pull the wheels and drums, while other ppl say I wont which is true? I know I'k have to:
Pull the rear diff cover
Unbolt the pinion shaft
Take out pinion shaft
Remove spider gears
Tap axles inward, C clips will fall out, remove them
remove washers from side gears..
i've got the actual removing the old carrier down, the only thing looking somewhat confusing is putting the new lockright in, Any help is VERY MUCH appreciated, I cant wait to get this thing going!
Remove spider gears
just checkin.
