lock-rite install??
I installed mine on a 12 bolt rear just using the instructions they supply and it was dead easy.
I can see it being a bit more involved on the front 44 though as (I think, depending on ratio) you'll have to pull the carrier to remove the ring gear which in turn would allow you to remove the centre pin.
i have a lockrite that was given to me, the problem is that it is still in a dana 44 ford axel, with 4-10s i am wanting to put it in my chevy 44 with 4.56s
