ExactlyKeep in mind there's a reasonable chance that this is just a way to try out what a locker is like and make a decision on what to do long term. Drop in lockers are awesome to do just that since they're cheap and the install is pretty easy. If you do anything different, DO NOT do it to your 28 spline 10 bolt. It's not strong enough to justify locker money. At least 30 spline shafts and a full housing swap to something like a 9.5" semi floater would be in order.
Don't get too wrapped up in it right now, put the lunchbox in there and go learn.
See belowMy issue with a TruTrac or any other limited slip is they might still leave you hanging in the situation you described. One tire in the air or both tires in slippery stuff and a limited slip reverts to one wheel peel.
Mine is the one from longbedder.In that situation where you want to be one and done I think what Stephen said the first time was the correct solution, a 14 bolt semi floater will let you keep your current wheels and tires.
If you were to change to a 14b full floater that is even stronger but you would need 8 lug wheels and a front 8 lug conversion.
I think the semifloater is plenty strong for what you are doing and @imiceman44 and @longbedder had one for sale previously if he is closer, maybe its gone.
Either way, get one of those two axles and put a Detroit locker or a selectable in that, done. I prefer the Detroit.
You’ll be able to install a lunchbox style locker yourself, very simple, just follow the directions, no gear setup needed. That’s assuming your 10 bolt is open as lunchbox style lockers won’t work in a g80 case.So I dont wanna buy something just to test it out because I would still have to pay to have it installed as I dont know how to myself. I want the permanent solution. I have to drive 3-5 hours to get to my hunting area/town then another 1.5-2 hrs into the mountains to camp. There is no phone signal out there if I get stuck so definitely don’t want to just trial something, I got lucky to run into someone to help me last time. So what’s the best solution?
Are Eaton E lockers any good, I’m looking into those and thinking of upgrading to 30 spline shafts.Get a Locker and do it once. No matter what work you go through or axle work you do in addition to getting a locker it will be a real locker that works. The limited slip will eventually leave you hanging. Literally.
I have one for the 9.5" and it's been great. There is a rumor that they unlock/lock each time you change directions, but I don't know if there's consensus on that. Keep in mind that you have to drill a hole in the axle housing, similar to what would be required for an ARB.Are Eaton E lockers any good, I’m looking into those and thinking of upgrading to 30 spline shafts.
I was just researching my options and the e locker sounded like a better option. This way I can turn it on and off and only use it when I have too in order to not damage rear end. But still looking into maybe just getting a stronger rear end and just putting the money into that instead.I have one for the 9.5" and it's been great. There is a rumor that they unlock/lock each time you change directions, but I don't know if there's consensus on that. Keep in mind that you have to drill a hole in the axle housing, similar to what would be required for an ARB.
By the way I really appreciate everyone for taking the time to reply to my questions. My apologies if I’m annoying you all. This is my first 4x4 vehicle I’ve ever owned so I don’t know anything about 4x4ing products. I am starting to learn a little so thank you all
I like the sound of this one
you can run an OX locker on cable, air or electric. the actuator goes through the cover so you don't have to drill a hole in the housing
Only problem ...... h2 is 8lugdidn't the eaton e locker come factory in H2s, probably not with 4.10 gears. A H2 axle might be a nice upgrade rear disc brakes too.
