Anyone ever seen one? Can't believe GM continued to use the same connector that (apprarently) doesn't lock. Maybe all the ones I've ever seen are broken, but it doesn't look like it ever locked like some of the other connectors.
Just wondering if there is anything else out there thats "standard" in it's readings for the 0-90 ohm gauge, that will actually lock. Usually not a problem, but was checking my wires, bumped that wire, didn't notice it, and it got a touch hot. Rather just prevent the problem if possible.
Don't really care if I have to swap the sender, as long as it's something I can find in the 'yards...maybe Vortec (since that's what my heads are with the "small" diameter temp sender), Van 4.3L or later SBC apps in the Camaro's?
Hmm, now that I think about it, did they ever combine the ECM and gauge senders? Never seen it, but since they did similar with the oil pressure switches/senders, it might exist?
