NEK5
3/4 ton status
another question. I don`t have the removable hump...how hard is that going to make the installation?
. Chrisblazzer89 said:What had allen heads ? What needed them and could I just go match them up with some hex head bolts?
bear76 said:How does the arm come off?
set screw in it. loosen that and slide the arm off.X2!!smalltruckbigcid said:If you have the glued down tunnel can you use a heat gun to loosen the glue and remove the hump?
bear76 said:Sorry I didn't have it in my lap to look at it. I'll try that tomorrow.
.I was really intrested in the answer to this ? any know the answer?smalltruckbigcid said:If you have the glued down tunnel can you use a heat gun to loosen the glue and remove the hump?
