longer brake lines...for dana 60
muddybuddy
1 ton status
Northern, VA
im in the process of buyin a dana 60, and i noticed that the brake lines are different from those used on a 10b. ive got 9" of lift, and i was using the right brake line off of a 2wd 93 2500 i believe (i got the part number off here, cheap longer brakeline) and it was working perfectly. i was wondering if i would be able to reuse these, or if there is a similar line i can take off another truck.
thanks
shouldn't be different. I had skyjacker extended lines on my 84 and 85 which both at Dana 60 front. The brakelines were for a K5 with a 10 bolt, bolted right up.
thanks, thats what i wanted to hear. i was looking them up at the local parts store and they had differnt part #'s so i thought they needed differemt ones
