Looking at a ‘76 how easy to add OD?
Fishwater2002
New Hampshire
I’m looking at a 1979 K5 and while I love the round eye style I’ll be driving it regularly so thinking I need to add OD (700R4) and I guess a NP208 while I’m there. I’ve read a few different threads and it sounds pretty involved with dealing with the four wheel drive selector linkage plus crossmember plus driveshafts. I’m actually pretty surprised that there isn’t a simpler option so wanted to throw it out there first for everyone’s opinion.
The funny thing is that I promised myself I wouldn’t go down this rabbit hole again and just wanted something simple to drive and enjoy but here I am :doah:
It's actually a lot simpler if you do 700r4 with a np208.
You need the adapter plate for the throttle valve cable at the carburetor, easy enough to find and then a complete set of transmission/transfer case and shifter.
A slight adjustment of the tunnel for the shifter and you're done.
Other than driveshafts which at this age you probably need something done on the driveshafts anyway.
I put one in a 74 but I went the hard way and adapted it to the np203 which meant changing the output shaft in the transmission so I rebuilt it while I was there
Just buy an overdrive one.
You can build anything out of these trucks, they all bolt together like Legos. You don't have to though, just buy the right one and enjoy.
Seems like it’s pretty easy, every Chevy I ever owned was pretty easy when it came to aftermarket mods but I’ve read some pretty involved steps to get to what should be a simple end.
Agreed, I’m a fan of the older round eyes but it’s so much easier to buy a newer one with TBI and OD done by the factory, they just don’t have the same look as the older ones.
I think what he meant was that it is pretty easy to put a round eye front clip on a newer model
Pardon my interruption… the link offers a pre 91 option, I have the trans and transfer case from Munepit (Jeff’s) 87 Suburban, likely a pre 91 but how do I make sure? I’m thinking I’m going to put it in my 68 K20.
from what I have seen it is 1993 and older use a TV cable and after 1993 use electronics to control shift; also the later ones have a lot more electrical connections
I’m pretty close to closing a deal on a ‘76 Jimmy so the OD idea will potentially be back on the table this winter. My plan is to drive it as is for the rest of this season and then do a swap in the winter but out of curiosity wondering how much mileage/drivabilityI’ll get by swapping out the original 350/203 combo. Correction it’s a T400 trans.
Currently the original numbers matching 400/T400/NP203/205(?) is in the truck which is pretty cool, this is going to be a weekend toy that never goes off road or driven as a daily commuter rig so it might not even be worth the hassle unless something is needing repairs which the owner is claiming that it does not. Does anyone have an idea on what they got as mpg before and after a swap like this? Just curious since I’m not buying this for mpg’s.
In general, as has been discussed here many times, you don't recover money on upgrades/changes because of improved MPG, you do it to make the vehicle more useable and enjoyable. That being said, OD may be one of the most effective upgrades on the MPG front. Plus, the TH400 and NP203 are about the worst in that respect. Googling for '79 400 Blazer shows 10MPG. You're moving to an early/mid 80's drivetrain, which shows up as 13MPG, although that's based on a 5.7L. Let's call it a 25% improvement, which is huge.
So if you drive 3000 miles per year, at $4/gal, the fuel goes from $1200 to $960. If you spend $2000 on the transmission and trans swap, you break even in 8.3 years.
You also need to look at what gearing is in the truck. Some 3-speeds got rather tall gears. An OD trans lets you go deeper and the whole vehicle is more enjoyable, but of course it increases the investment.
If you're swapping a lot of drivetrain parts at once and MPG and reliability are big interests, you might at least weigh the option of an LS swap.
I don’t see which gear ratio, no RPO code listed except for the G80 locker, so I’m not sure but the 1976 brochure lists 3.73 or 4.11 for towing and this truck came with the towing “device” Actually it’s a pretty nicely optioned truck which is cool….
Either one of those ratios could work if you're sticking with stock (-ish) size tires. It's a 50-year-old truck. Don't assume nothing has been swapped over the years. The easiest way to tell is to lift the rear axle and count driveshaft vs. tire revolutions. The most sure-fire way is to pop the differential cover and count teeth, or read the stamping on the edge of the ring gear.
Yes, the plan is to drive it for the rest of the season. It’s a long cold winter in New Hampshire so I typically do a larger project over the winter so it’s ready for spring, IF I were to do a trans swap it would be then but we will see how it goes.
I drove my 74 for 3 months and the 3000 rpm highway driving got to me so I put a 700r4 in.
I had to change the output shaft because I had the 203/205 doubler but other than that easy job.
That’s what my thought is, the GTO I just sold was a four speed with 3:23’s which isn’t a bad gear but on the highway it was almost 3,000 RPM’s and it got to me as well so I’ll go to an OD if necessary with this rig.
Are you saying that the transmission and transfer case have been changed ?
A Blazer/JIMMY in 1976 with a 400 engine would have only come with a TH350/203 combo - TH400/203 first year was 1977 and only in 3/4 & 1-Ton trucks and the TH400/205 setup wasn’t offered until 1980 ( and only in 3/4 & 1-Ton trucks ).
Since your JIMMY doesn’t specify a gear ratio code on that SPID that indicates that it has the standard gear ratio which is a 3.07 ( see pic of standard ratios ).
Adding an O/D to a 3.07 geared truck might put the RPM’s a little low and hurt the driving experience.
Take some good pictures of your trans & T-case and we can identify what you actually have and possibly explain the easiest route to a trans swap.
