Looking for a 2wd box to convert to Crossover steering
sw99
Colorado
I have an 86 K30 and need a 2wd box to finish my crossover. Txs
Forgot to check mine. I'll take a look and let you guys know. Thanks.
Was is 86' and on that had the o-ring? I just pulled one from an 89' 2wd 3/4 ton suburban and was going to put in my 87' Suburban.
I need this other one for my 86' K30.
81 and on had Oring so your 89 will work as will any 81 and up.
just pull the sector shaft at the jy, drop it in you existing box on the k30...Easy swap if you have a puller.
