Looking for a Cummins 3.9BT specific forum, Help!
grimjaw
Seymour, TN
I am looking for a Cummins 3.9BT specific forum. ANyone know of a good one? I am getting comparison info together for different diesel options. Thanks.
Whar are you doing the research for?
I haven't found a 3.9 specific forum but I know of a couple of guys that have it in their K5 and they say it works great.
I am comparing the cost, reliability, possible power, fuel economy and ease of swap between the GM 6.2 -6.5 and Cummins 3.9BTs.
I have that group. I am just looking to see if there is any more places to get info.
Thanks.
It would help if there was a program like Desktop Dyno for Diesels.
Cummins 3.9
What info do you need ,I can help with the parts I have a complete P 30 .
ask away.
3.9 can get up to 25 mpg with good power,say 300HP
A 6.2 or 6.5 can't come close and won't last as long .
(My bother is doing a 3.9 in his 84 Blazer,he just getting parts together ).
P.S my shop is moving to knoxville, TN
CrewCab59
crawlink5 on this site just finished his conversion in a 79 blazer, we got it on the road yesterday.
I'm going to be dry fitting mine with the body on soon as well in my 86
here is a dyno curve on the 4bt.
Ease of swap obviously goes to the 6.2 or 6.5 as they are straight bolt ins.....
here is a pretty good 6.2 build
http://community.webshots.com/album/286393940AoOzqp
crawlink5 said:
I certainly like the engine! If I can just get my brakes working...
To hijack my own thread....Hydroboost brakes are your friend.
ask away.
CrewCab59
I am interested in what is needed to get 240+hp 450+tq and keep 25+mpg. Is this using comman parts or do you need that rare, only made 30 years ago, part?
Yes indeed
Basically turning up the fuel pump starts barking out the tq and HP, however that starts = fuel mileage loss, I'll have to find the spec sheets I had printed, I believe the 4bt that I saw with simillar numbers to what you posted was down in the teens on mileage. Still beating a gas motor though.
You can also look at interchanging turbos with a 6bt for a quicker spool and more low range pep, they make higher flow injectors, pumps, etc etc......by no means is the block, internals, or compression a limiting factor.
What type of injection pump is on these 3.9's? Are they rotaries like the VE 5.9's or are they inline pumps like the P7100 on the P series?
If it's an inline bosch pump you could maybe modify the fuel plate for more fuel just like the 12v 5.9's are capable of.
An HY35 quick spool turbo like what is on my '01 Ram auto would work perfect on the 3.9. the HY is good for basically 300HP and spools quick. The HY doesn't leave much room for fuel on the 5.9's and you could pick up an HY for cheap because of that reason, they get tossed if you want to make more than 300HP and actually tow at the same time.
