rampage
3/4 ton status
sorry dad. read the thread. the first thing checked was the rear end. I’m skeptical of the annulus gear bouncing around and having a recommended shop telling me it’s fine to bounce around
i’ll see what happens once i get the Tcase back in. it’s a bummer, rear differential looked fine to me, the shop confirmed it and said Tcase was the issue, some people on the thread have described similar 208 issues so…one step at a time guess?I would kind of like a shop to tell me they don't want to take more of my money than necessary. Usually, a shop is all too eager to do what you tell them is wrong, then fix what is actually wrong when you bring it back with the same problem. It would seem, however, that if your rear end is good, and your T-case is good, the only thing left would be your driveshaft. If you've got the ouput on the trans moving, and the T-case is good, then the only link between there and the known good rear end is the driveshaft. Unless maybe you've snapped both axles. I'll second Roberts Custom Trucks, but he's not quick. He's more of a custom build type of guy, but he does know his stuff.
yes im aware of that. the Tcase was already out so i figured may as well pull it apart and look. while it was out i put a breaker bar on the rear diff yoke to see if it would slip, it was tight and moved the truck with my 210lb ass jumping on it so…The thing is...the T-case has a main shaft that passes all the way through from the front planetary to the rear output. It's the front output that disconnects, so a lack of rear drive is in the rear end, driveshaft or maybe stripped splines for the yoke.
You can easily diagnose this through observation if you have a helper.
no unfortunately i tossed it out. there wear on it was way beyond usable and the seam was separated. from my understanding they are supposed to be tight as **** and bed in over time.Have any photos of the bushing? It’s been a while since I had a 208 apart, but I also have a hard time thinking of where all this slipping could happen when the main shaft passes directly out of the planetary assembly to the rear driveshaft?
I’ve had a couple 241s apart recently and they are really similar
Huh. In any of the 241s I’ve cracked… I don’t remember any amount of noticeable play in those components… (I know this is apples/oranges and the 241 has the oil pump)i have the Gm schematic so numbers are different but worn parts were as follows:
1. annulus gear bushing (steel/brass) we call it a Du Bearing in the cycle world
2. low range lock plate
3. synchronizer shift struts
once replaced, i could not turn or shift without by hand without a lot of force…major difference bench testing , i gotta imagine the amount of play was the cause of 2wd going out.
when it was removed it had a ton of rattling, i was expecting to have a bunch of metal fall out…nothing beyond what was in the magnet. the shift forks had some gouging, but bushings were in good shape, so maybe from the previous ohaul.When I first read your thread here, I was worried we would find out this is a 700r4/4l60 transmission issue… (I have general distrust issues with those things!)
But interesting read, and thanks for the recap on the transfer case!
