Looking for a tapping machine??
I agree about the machine. I have used one of those others and loved it. My problem was I was having to tap hundreds of holes on vertical surfaces, or on machines that were too big to lay under the tapper.
That Sioux drill, which I don't see on their website, had the chuck at about a 70 degree angle instead of a full 90, and made getting them straight a lot easier than normal.
Later, when I was having to do a lot of drilling and tapping 10-32 holes, I used some of the drill/tap combinations.
Really sped things up. It had the correct sized drill bit on the end followed by the tap. Combine that with a quick reversible drill, you can really go to town.
Glad to help!
Now that you have it you'll be looking for a ton more work involving a lot of tapped holes! It should be a good money maker for you!
Rene
Grab yourself a small cup of some sort. Fill it with cutting fluid. Before each hole, dip the tap in the cup and go to work. Very convenient with that setup.
Just make sure if you have a cup of some kind of beverage nearby, its in a very different cup.
I never went all the way, but I did have the cup of lube in my hand halfway to my mouth.....
