Sqeejo
The driver side seat bracket broke and now I need either a replacement bracket or aftermarket seats. I am new to the Blazer community and desperatley need help.
Where is your bracket broken? If you can post pics of if it would help. I may be able to help you out either getting it fixed or getting a replacement.
What year truck ? Blazers in the 80's and 70's use different floor brackets , but the seats themselves have the proper nut inserts in all the right spots . So any Blazer seat will interchange with your year mounts .
And mounts are easy to come by with people cutting up rigs all the time . I have 70's brackets in my garage collecting dust .
Several years ago I drove a Dodge Omni to work ( about 40 mpg ) every day. The spot weld in the seat back broke and I brought it to an automotive upholstery shop. I removed the seat and had them fix it. Cost $20. If the seat upholstery is in good shape it might be cheaper to get it fixed. If it is worn out or beat to hell replace it.
I have an 83 Blazer.
I have a set of seats that I am not using that came out of my 91 K5. If they will work for you let me know. You are welcome to them.
Little to nothing for them. If you want to come by and check them out let me know. I have them out at a buddies out on 1585 in Lubbock.
