Looking for an over drive trany
  • Thread starter **DONOTDELETE**
  • Start date
D
**DONOTDELETE**
Guest
I am looking for someone who nows where I can get a GM 700R overdrive trany for my K5. I have a Pontiac 428 V8 and a th350 trany and a NP205 in it right now. Or can someone let me now what kind of trany I should go with for the type of motor, its pushing 380 hp for now.
Thank you
Spring Lake! Wow, another NC wheeler, and I actually know where Spring Lake is!!! /forums/images/graemlins/grin.gif Yep, I've got one for sale. Check it out in the For Sale forum.
I don't think there's a BOP bellhousing tranny with overdrive other than the TH200-R4 /forums/images/graemlins/tongue.gif
When I worked at a wrecking yard, one of the guys made a bellhousing adapter (to run, say a TH700 on a Buick/Olds/Pontiac) out of 1/8" steel plate. The plate has both the BOP and Chevy bolt patterns on it. The four lower holes just get the usual bolts through it, while the upper holes on the Pontiac block and Chevy tranny get bolted to the plate itself. Then use 1/8" thick washers between the flexplate and torque converter.
